hoss Postad 27 April , 2014 Rapport Share Postad 27 April , 2014 Hi Gripen - Which gearbox do you have? Do you know the length measurement? I just made some approximate measurements and i seems i may have to move back more than 50mm. I have the 5-speed auto (722.6) Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gripen Postad 27 April , 2014 Författare Rapport Share Postad 27 April , 2014 Did you put an additional bearing in the front as Daniel and Fredrik have done? or just a seal? No, I have not installed any extra bearings in the cover. With my custom made shaft i saw no reason to do so. I think the bearings in the transfer box are strong enough, they look kind of oversized to me. /Gripen Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gripen Postad 27 April , 2014 Författare Rapport Share Postad 27 April , 2014 Hi Gripen - Which gearbox do you have? Do you know the length measurement? I actually have not been able to find out which type of gearbox i have, but it is 5 speed. I can measure how long it is tomorrow. /Gripen Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gripen Postad 28 April , 2014 Författare Rapport Share Postad 28 April , 2014 Hi Paul! My gearbox is approx 470mm in length, and it is stamped with the number 170 260 00 00 717 460 0 7255301. It also has a label with a barcode 7255301 4 /Gripen Citera Länk till kommentar Dela på andra webbplatser More sharing options...
hoss Postad 30 April , 2014 Rapport Share Postad 30 April , 2014 Hmm my gearbox is 600mm from the engine to the face of the 3 point drive flange.. I think i will have to move the transfer box maybe 200-250mm! which means modifying the chassis Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gripen Postad 5 September , 2014 Författare Rapport Share Postad 5 September , 2014 Efter att bygget har stått still lite väl länge så börjar det äntligen röra på sig, och jag har fått tummen ur och införskaffat en mekanisk insprutningspump som ska ersätta den elektroniskt styrda pumpen som sitter på motorn nu. Tyvärr passar den inte rent fysiskt, den är för lång! Jag håller som bäst på att undersöka om den elektriska tomgångsstabiliseringsenheten går att bortrationalisera, då kommer den förhoppningsvis att passa... Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Tjingen Postad 5 September , 2014 Rapport Share Postad 5 September , 2014 Kul att du är på gång igen! Den här är ju en tråd man sett fram emot. Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gripen Postad 8 September , 2014 Författare Rapport Share Postad 8 September , 2014 Hmm... lite bakslag, efter teknisk konsultation med Dieselmeken Göran så har det framkommit att denna pump inte kommer att passa på min OM605. Regulatorn behöver stabiliseringsenheten för att fungera. Jag behöver en pump från en icke turboladdad OM605 eller en OM602, bara att börja jaga... En annan lösning kan vara att flytta motorns oljekylare och filter, men det är jag inte så sugen på. Citera Länk till kommentar Dela på andra webbplatser More sharing options...
case Postad 10 September , 2014 Rapport Share Postad 10 September , 2014 Jag har en som inte har någon elektrisk tomgångshöjning på min bil och den passar fint . Höjer min tomgång med vakuum istället men det höjer väldigt marginellt . Han satte på en alda klocka som ska va en rökbegränsare på min men ja vet inte om det va nått och ha i slutändan . Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gripen Postad 10 September , 2014 Författare Rapport Share Postad 10 September , 2014 Hej Case! Har du också en OM605 i din bil och en pump som är fixad av Dieselmeken? Citera Länk till kommentar Dela på andra webbplatser More sharing options...
case Postad 11 September , 2014 Rapport Share Postad 11 September , 2014 Japp samma motor och 6mm element som diselmeken pillat dit . Mvh Henrik Citera Länk till kommentar Dela på andra webbplatser More sharing options...
bloodwheel Postad 11 September , 2014 Rapport Share Postad 11 September , 2014 Det här ser ju väldigt bra ut....... Hoppas du löper linan ut och blir färdig! trevligt trevligt.... Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gripen Postad 11 September , 2014 Författare Rapport Share Postad 11 September , 2014 Japp samma motor och 6mm element som diselmeken pillat dit . Mvh Henrik Det låter ju väldigt intressant. Har du bytt till en mekanisk pump, och har du i så fall någon beteckning på pumpen, eller vet vilken motortyp den kommer från? Citera Länk till kommentar Dela på andra webbplatser More sharing options...
case Postad 12 September , 2014 Rapport Share Postad 12 September , 2014 Ge mig din mail så ska ja skicka ett kort på min pump . Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gripen Postad 9 Januari , 2015 Författare Rapport Share Postad 9 Januari , 2015 Nu har jag äntligen kommit vidare med projektet, karossen är pålyft för att undersöka vad det finns för plats för insug, generator etc. På bilden sitter karossen 150mm högre än original, men den ska sänkas 100mm. Det blir nog lite klurande hur all kringutrustning ska få plats, men det ska bli kul och det är klart uppmuntrande att se karossen vilandes på ramen... /Gripen 10 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gripen Postad 16 Januari , 2015 Författare Rapport Share Postad 16 Januari , 2015 Äntligen är bilen klar, det var lite pyssel, men slutresultatet blev skapligt faktiskt... Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Frippe S Postad 16 Januari , 2015 Rapport Share Postad 16 Januari , 2015 Och var är alla bilder på kluriga/snygga lösningar man blivit bortskämd med tidigare 1 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gripen Postad 16 Januari , 2015 Författare Rapport Share Postad 16 Januari , 2015 Ja, pappmodellen alltså, fullskaleprojektet rullar vidare :-) ... 7 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
JDW Postad 16 Januari , 2015 Rapport Share Postad 16 Januari , 2015 Aha, design brandkår som gäller? Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gripen Postad 16 Januari , 2015 Författare Rapport Share Postad 16 Januari , 2015 Nja, den får nog förbli gul. Men då jag ska modifiera fronten lite på bilen, bl.a. med dubbla strålkastare, så satt jag och bildsökte på Google för inspiration, och då kom detta upp... http://www.bestpapermodels.com/en/papercraft-1-35-volvo-c-305.html /Gripen 1 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Frippe S Postad 16 Januari , 2015 Rapport Share Postad 16 Januari , 2015 snyggt diorama Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gripen Postad 9 Februari , 2015 Författare Rapport Share Postad 9 Februari , 2015 Nu är distanserna för att höja karossen 50mm klara. Nordbergs Tekniska AB levererade lämpligt material... Polyamid smord med MoS2. Gjuten PA-6 smord med molybdendisulfid, MoS2. Ökad kristallinitet ger bättre nötbeständighet och lägre friktion. (Nylatron GSM) /Gripen 5 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Pebl Postad 10 Februari , 2015 Rapport Share Postad 10 Februari , 2015 Ah, Nylatron GSM! -Det gör vi linhjul av på Jobbet, Börjar med en liten nätt fyrkantsbit på 1100x1100x100mm och blir ett linhjul på ungefär 1050 i diameter. Fick några spillbitar som blir av hörnen på den fyrkantiga biten, väldigt bra att göra småsaker i garaget av. Jobbigt att såga ut lagom bitar bara. Motorsåg funkar bäst. Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Svana Postad 10 Maj , 2015 Rapport Share Postad 10 Maj , 2015 Gripen..finns du kvar? Har du bilen kvar? Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gripen Postad 20 Juni , 2015 Författare Rapport Share Postad 20 Juni , 2015 Öh... host host, både jag och bilen finns kvar, men det händer inte mycket i verkstaden tyvärr :-( /Gripen Citera Länk till kommentar Dela på andra webbplatser More sharing options...
