Leon_pp Postad 17 Mars , 2015 Rapport Share Postad 17 Mars , 2015 Hi, On my '79 C202, my rear axle decided to died. The pinion gear is out. Is the C202 axles are a DANA 30 compatible parts? What is the stock gear ratio? If anyone have a pair of block diff with ring and pignion to sale, i need them pretty fast. Thanks a lot Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Leon_pp Postad 17 Mars , 2015 Författare Rapport Share Postad 17 Mars , 2015 seems it is a Dana 44 axle, can anyone confirm? Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Jocke W Postad 17 Mars , 2015 Rapport Share Postad 17 Mars , 2015 Yes, it's Dana44 axle and ratio is 6.17:1 2 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Leon_pp Postad 18 Mars , 2015 Författare Rapport Share Postad 18 Mars , 2015 thanks going to look to buy 2 set of 5.38 to get a little longer with my futur B230ET 1 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Taavi14 Postad 2 April , 2015 Rapport Share Postad 2 April , 2015 Please let us know how this modification worked out. 6.17 ratio parts seems to be C202 specific and hard to find. Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Leon_pp Postad 3 April , 2015 Författare Rapport Share Postad 3 April , 2015 i find 6.17 gears but 3x the price of a 5.38 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Leon_pp Postad 7 April , 2015 Författare Rapport Share Postad 7 April , 2015 Just bought my first ring set from Amazon.com For a total of 65€. I shiiped it to a friend in USA cause amazon.com won't ship it oversea. http://www.amazon.com/Yukon-D44JK-538RUB-Performance-Gear-Differential/dp/B0078UA316/ref=sr_1_19?ie=UTF8&qid=1428398135&sr=8-19&keywords=dana+44+5.38 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
