plundh Postad 18 Augusti , 2016 Rapport Share Postad 18 Augusti , 2016 Hi- A long time ago I saw the 12V cigarette lighter socket in my Sugga (TP21). I have since forgotten where it was located and simply can not find it anymore. Could someone please help me refresh my memory. Many thanks. -Peter Citera Länk till kommentar Dela på andra webbplatser More sharing options...
KristianEriksson Postad 20 Augusti , 2016 Rapport Share Postad 20 Augusti , 2016 Could it be on The radio table? Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Glynn Postad 21 Augusti , 2016 Rapport Share Postad 21 Augusti , 2016 Between drivers seats with mt920 plugged in! Citera Länk till kommentar Dela på andra webbplatser More sharing options...
contango Postad 31 Augusti , 2016 Rapport Share Postad 31 Augusti , 2016 yes, between front seats with socket in direction downwards. you should find the screw holes in the wall. a cigarette lighter will not fit in because the plug/socket is the small one. Best, Matthias Citera Länk till kommentar Dela på andra webbplatser More sharing options...
plundh Postad 1 September , 2016 Författare Rapport Share Postad 1 September , 2016 Hi- Yes, I found a small socket on the MT920. Thanks much all! -Peter Citera Länk till kommentar Dela på andra webbplatser More sharing options...
tator Postad 5 September , 2016 Rapport Share Postad 5 September , 2016 Have you the original socket/contact to the car. Not the one on the MT 920 but the one in car? I have a new one if you need one. mvh tor a Citera Länk till kommentar Dela på andra webbplatser More sharing options...
