Bearings / Kullager
hoss
To answer my own question, i researched and found the following:
Item                            Volvo number                  OEM
Needle bearing           183637-8                        INA BK4520
Axle bearing                11017-1                          SKF 6210
Inner wheel                 183430-8                        Timken JLM10498 + JLM104910
Outer wheel cup         183505-7                        Timken JLM508748
Outer wheel cone       183506-5                        Timken JLM508710
  • Like 5
