Glynn Postad 1 Mars , 2017 Rapport Share Postad 1 Mars , 2017 Hi all Does anyone have a translation of b36 carburettor set up. My carburettor is running very rich and I cannot improve it. Mainly the t link vacuum assembly and accelerator pump and mixture. Thanks Citera Länk till kommentar Dela på andra webbplatser More sharing options...
SweMob Postad 2 Mars , 2017 Rapport Share Postad 2 Mars , 2017 Have you checked float valve?Had same problem on a Dodge.Leaking float valve. /Mats Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Glynn Postad 2 Mars , 2017 Författare Rapport Share Postad 2 Mars , 2017 It's new mats and appears to seal by blowing through it Citera Länk till kommentar Dela på andra webbplatser More sharing options...
