Landy Postad 17 Juni , 2017 Rapport Share Postad 17 Juni , 2017 Hi ! A friend just bought a C304. He want to join the community but it's impossible because you have a forum bug : Warning: require_once(/home/63/w173759/terrangbil/forum/admin/applications_addon/ips/nexus/sources/packageCore.php): failed to open stream: No such file or directory in /home/63/w173759/terrangbil/forum/admin/applications/core/modules_public/global/register.php on line 300Fatal error: require_once(): Failed opening required '/home/63/w173759/terrangbil/forum/admin/applications_addon/ips/nexus/sources/packageCore.php' (include_path='.:/opt/php/5.4.45/share/pear:/home/63/w173759/terrangbil/forum/ips_kernel/') in /home/63/w173759/terrangbil/forum/admin/applications/core/modules_public/global/register.php on line 300 Thank you 1 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Wingflyer Postad 17 Juni , 2017 Rapport Share Postad 17 Juni , 2017 Landy, Have your friend send me an email to: sten.svensson @ terrangbil . net (remove spaces). I'll then enter him manually. Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Landy Postad 17 Juni , 2017 Författare Rapport Share Postad 17 Juni , 2017 Thank you i will send a message to him Citera Länk till kommentar Dela på andra webbplatser More sharing options...
