Damian Postad 6 September , 2019 Rapport Share Postad 6 September , 2019 Good Morning from Zambia! On the below picture, it seems to be a clear hole in the rubber cap, which leaks ATF consistently from the gearbox. Is this normal? 2 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Svana Postad 23 September , 2019 Rapport Share Postad 23 September , 2019 Wrong forum my friend.. Citera Länk till kommentar Dela på andra webbplatser More sharing options...
kristaga Postad 23 September , 2019 Rapport Share Postad 23 September , 2019 13 timmar sedan, Svana säger: Wrong forum my friend.. I have moved the thread to the correct group. I hope some of the TGB30/40 experts here can help Damian. 1 1 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
yoda Postad 24 September , 2019 Rapport Share Postad 24 September , 2019 i Think the seal inside the rubber is bad 1 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Damian Postad 24 September , 2019 Författare Rapport Share Postad 24 September , 2019 8 hours ago, yoda said: i Think the seal inside the rubber is bad Thanks Yoda - so it is not normal? I will remove the rubber and see what I find... Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Halfsafe Postad 24 September , 2019 Rapport Share Postad 24 September , 2019 Are we talking about this one? 2 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Damian Postad 27 September , 2019 Författare Rapport Share Postad 27 September , 2019 On 9/24/2019 at 11:26 PM, Halfsafe said: Are we talking about this one? Yes thanks - so that gives me an idea what to look for, and that it can be fixed! 2 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
