rob582 Postad 3 Februari , 2020 Rapport Share Postad 3 Februari , 2020 Hi, I recently purchased this and I accidently shorted out one of the spare battery cables on the chassis (using one 12V instead of the old 2 X 6V setup). I have read in the instructions that I need to change fuse number 4 but have no idea where that is. I have checked the 4 fuses behind the control panel but they seem ok. Does anyone have any experience with these vehicles? I have all of the original documentation if required. I understand Swedish so please respond likewise. Cheers. Citera Länk till kommentar Dela på andra webbplatser More sharing options...
H.Hansen Postad 3 Februari , 2020 Rapport Share Postad 3 Februari , 2020 Ser ut som den sitter på baksidan av panelen på bilden. Om det är den säkrings hållaren nr 4 sitter i. Citera Länk till kommentar Dela på andra webbplatser More sharing options...
