Alec Mumford Postad 4 Mars , 2020 Rapport Share Postad 4 Mars , 2020 My vehicle has come without an age-related plate so I can't tell the age of it is there anyway to anybody knows how to decode the age Citera Länk till kommentar Dela på andra webbplatser More sharing options...
H.Hansen Postad 4 Mars , 2020 Rapport Share Postad 4 Mars , 2020 Is it an military. Then all are market 1975. It had to do with dispence. They ordered them I a batch. And then they delivered them wen they was built But all get 1975 as the year the was made. Civilian is little different Citera Länk till kommentar Dela på andra webbplatser More sharing options...
pbv301 Postad 4 Mars , 2020 Rapport Share Postad 4 Mars , 2020 If you have a Swedish registration number for the vehicle you can check here; https://fu-regnr.transportstyrelsen.se/extweb/UppgifterAnnatFordon/Fordonsuppgifter Under "Status" there is "Påställt första gången" and a date. That is the date when (for ex-military vehicles) they were first registered by the military (most often between 1975 and 1979). Under "Sammanfattning" there is "Fordonsår" and that is as mentioned earlier in most cases 1975 for the TGB 11 (4x4) and TGB 13 (6x6). The TGB 20 (flatbed with back-to-back seats), from where your pictured sign originates, are in most cases manufactured later, say early to mid 1980's. It also has five forward gears as opposed to four on the TGB 11 and 13. The sign in your picture is on a TGB 221, originally used by anti-aircraft platoons for transporting men and anti-aircraft missile launchers RB70 and later RB90. The back-to-back seats covers 2/3rds of the flatbed, the last 1/3rd is storage for the missile gadgets, accessible from the rear of the vehicle. /pbv301 3 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Alec Mumford Postad 4 Mars , 2020 Författare Rapport Share Postad 4 Mars , 2020 You are correct this was a flatbed troop carrier and it does have a 5 speed gearbox 2 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Pvpjtgb1111 Postad 4 Mars , 2020 Rapport Share Postad 4 Mars , 2020 TGB20 often has model year 1979 or 1980 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
