Wheel stud size L3314?
Does anyone know what the size and thread pattern is of the military L3314 wheel studs and nuts?
Are they metric or inches?
I measured with a set of calipers and got around 12.4 to 12.6 mm. The wheel nut fitted nicely on an M12x1.25 tap (gängtappar) but the M12x1.25 die (gängdies) wouldn't thread onto the stud. Sorry for my bad Swedish!
So are they 1/2" UNF? I only have a metric tap and die set.
The Norwegian Forsvaret parts catalogue does not give any sizes.
Still waiting for my paint to arrive by ship from the mainland so I can finally finish and install my fuel tank on my Svalbard Feltwogn.
