Frank H Postad 31 Augusti , 2020 Rapport Share Postad 31 Augusti , 2020 Hej together, I am looking for a set of wheel bearings for the Valp front axle. Mine are a bit to noisy, so they seem to be worn. Does anyone have the SKF or Timken partsnumber or has bearings for sale? Additionally I need some tie rod ends for the steering linkage(left and right). Thank you very much. MVH, Frank Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Volvo Laplander Camper Postad 31 Augusti , 2020 Rapport Share Postad 31 Augusti , 2020 PM Hansen maybe he has some left in stock after last ordering. Citera Länk till kommentar Dela på andra webbplatser More sharing options...
H.Hansen Postad 31 Augusti , 2020 Rapport Share Postad 31 Augusti , 2020 I got 4 berings for sale. It`s needed for change both side of the axel, It´s Timken bering The bering number is L102849/L102810 1 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
