Dokatd Postad 19 Oktober , 2020 Rapport Share Postad 19 Oktober , 2020 I have searched and searched but cannot find an answer. I need a pair of 12V wiper motors and I would prefer the original civilian style or at least something that bolts right in. Any help is appreciated I got this photo that is supposedly from a civilian C303 but the numbers don’t pull anything up for me. 1 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
JDW Postad 20 Oktober , 2020 Rapport Share Postad 20 Oktober , 2020 i bought a used one from www.tatanka.nu (they have 12V parts on stock, but not always exposed in webshop) 1 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Dokatd Postad 20 Oktober , 2020 Författare Rapport Share Postad 20 Oktober , 2020 I tried them but all they had was a lot with all the 12V parts. I didn’t need the majority of them as my truck is far from stock. I will try them again though. Surely they are a available new. 1 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
jim molloy Postad 22 Oktober , 2020 Rapport Share Postad 22 Oktober , 2020 The 1 562 660 is one of two Volvo part numbers for a 12V wiper motor in the Vovlo TGB parts manual. The full number is 1562660-9. The earlier number is 1560260-0. 1 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Dokatd Postad 24 Oktober , 2020 Författare Rapport Share Postad 24 Oktober , 2020 Sadly those numbers don’t pull up anything of consequence via google. Really shocked these aren’t more common parts. Citera Länk till kommentar Dela på andra webbplatser More sharing options...
JDW Postad 24 Oktober , 2020 Rapport Share Postad 24 Oktober , 2020 Most of the TGB parts is from other Volvo products, engine from 164 and many small parts from truck's and tractor program at that time. But of cource, all the electric is 24V. Anyhow, the civil viper motor isn't special built for TGB, probably a standard Bosch or VDO product, or maybe from Land Rover?? Claes at Tatanka do certainly know where it was manufactured and in which other veichles it is used. Citera Länk till kommentar Dela på andra webbplatser More sharing options...
JDW Postad 24 Oktober , 2020 Rapport Share Postad 24 Oktober , 2020 www.motoroldies.se is a webpage where some standard 12v part is availible. 164 (engine) and Amazon have many parts in common with TGB. You have to search for the part or number, but there is many pictures (not for torkarmotor though) Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Dokatd Postad 25 Oktober , 2020 Författare Rapport Share Postad 25 Oktober , 2020 I’m going to rewind one and see how it works. Not hard, just a pain. 2 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
jim molloy Postad 28 Oktober , 2020 Rapport Share Postad 28 Oktober , 2020 You may wish to try this gentleman. He is a vintage European wiper expert. He converted a pair of 24V TGB wiper motors for us a couple years ago. Flawless function and workmanship. Don West ("The Wiper Guy" in vintage VW circles) 3730 NE Grandhaven Dr. McMinnville Oregon 97128 Cell#(503)434-3530 Home#(503)434-6486 Hope this helps. Jim Molloy 4 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
hoss Postad 19 November , 2020 Rapport Share Postad 19 November , 2020 I would really like to find some. Its the last thing on my trick thats 24v (running a 12-24 converter just for those). If anyone finds a source to buy them, please post here. Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Volvo Laplander Camper Postad 19 November , 2020 Rapport Share Postad 19 November , 2020 Why not buy the marine one like this, if it for headlight cleaning I have 2 12volts but one is stuck and one working Citera Länk till kommentar Dela på andra webbplatser More sharing options...
