rob582 Postad 9 Augusti , 2021 Rapport Share Postad 9 Augusti , 2021 Hi, I just switched out the ignition system for the engine as the electronic didnt work so well. The engine now runs like a dream. I cannot get any measurements from any of the meters on the generator and there is no voltage. Has anyone the knoweledge or experience of what the issue may be? The återställning and prov buttons also do nothing. I fully understand Swedish. Cheers. Rob Citera Länk till kommentar Dela på andra webbplatser More sharing options...
JDW Postad 10 Augusti , 2021 Rapport Share Postad 10 Augusti , 2021 Antagligen diodbryggan som inte vill vara med. Citera Länk till kommentar Dela på andra webbplatser More sharing options...
rob582 Postad 10 Augusti , 2021 Författare Rapport Share Postad 10 Augusti , 2021 15 minutes ago, JDW said: Antagligen diodbryggan som inte vill vara med. I have searched the manual and cannot find this part. Is it in the växelströmsgenerator? Citera Länk till kommentar Dela på andra webbplatser More sharing options...
johngbg Postad 11 Augusti , 2021 Rapport Share Postad 11 Augusti , 2021 Perhaps in need of flashing/polarizing? If it's been out of use for a longer period it might fix it. Citera Länk till kommentar Dela på andra webbplatser More sharing options...
JDW Postad 12 Augusti , 2021 Rapport Share Postad 12 Augusti , 2021 På 2021-08-10 på 20:26, rob582 säger: I have searched the manual and cannot find this part. Is it in the växelströmsgenerator? Yeah, its in the växeltrömsgenerator, in the "neutral" point. As the military gen sets are made to be stockpiled for many years, i thinkt there are permanent magnets and enough filed to create at lits some voltage. Citera Länk till kommentar Dela på andra webbplatser More sharing options...
rob582 Postad 12 Augusti , 2021 Författare Rapport Share Postad 12 Augusti , 2021 21 hours ago, johngbg said: Perhaps in need of flashing/polarizing? If it's been out of use for a longer period it might fix it. Thanks for the tip. I was only getting 12v to the control panel so i connected an electric drill ran it forwards and then reversed the chuck and now I have 220v coming out! Cheers. 5 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
johngbg Postad 12 Augusti , 2021 Rapport Share Postad 12 Augusti , 2021 Glad it helped bud! Citera Länk till kommentar Dela på andra webbplatser More sharing options...
