darius_ro1 Postad 18 Mars , 2013 Rapport Share Postad 18 Mars , 2013 Hi, is there anyone who made a type homologation (like the one made with TUV of other similar bodies) of the TGB 1314 with OM 606 engine or others? Here, if we change the engine with other that was never homologated by the manufacturer for the respective vehicle, some extensive testing and individual type homologation has to be completed. I was advised by this department of motor vehicles to try find if such a vehicle is homologated with respective engine or it is homologated for competition (that seems to easier to deal with in terms of modification accepted) in other countries. Thanks, darius Citera Länk till kommentar Dela på andra webbplatser More sharing options...
hansrover Postad 18 Mars , 2013 Rapport Share Postad 18 Mars , 2013 Jamen mycket blir sagt..... Min 603960 Mersadieseln funkar grymt bra, tillsamans med automatlådan, finfin på vägen, och helt grym i terränglådan. Automaten kommer ifrån Range Rover 3,9 lit EFI ZF 4HP22, och fördelningslådan är en tillhörande LT 230 och ingen viskokopling, som är moddad i mellan devet, som jag köpte ifrån Asckroft LTD, så nu har jag en utväxling 1:002, perfekt för portalaxlade bilar. Marsar 80 km 1800 rpm. hejs Citera Länk till kommentar Dela på andra webbplatser More sharing options...
darius_ro1 Postad 18 Mars , 2013 Rapport Share Postad 18 Mars , 2013 Hi Frederick, I saw on some other subject that you managed to receive a document from Volvo stating that you may use OM 606. Would you please help me a little on this issue? What did you have to do in order to get it? Did you make a type homologation/certification/type registration with this engine in your country? I need to do something similar if I change the original engine with something that was not installed by the manufacturer originally. If there is such registration elswere in EU, might work fo me if our local authority may get the data from an european data base. Thank you Darius Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Fredrik L Postad 19 Mars , 2013 Författare Rapport Share Postad 19 Mars , 2013 Hi Darius. I have a document from Volvo but it does´nt specify that i can use a OM606. It´s just states that the brakes and axels can handle the load from an engine with 130Kw and 330Hp. Kurt Björk is the Volvo guy who writes all the documents we need to register a modification here in Sweden. Mabye he can help you to? kurt.bjork@volvo.com Fredrik Citera Länk till kommentar Dela på andra webbplatser More sharing options...
darius_ro1 Postad 19 Mars , 2013 Rapport Share Postad 19 Mars , 2013 Thank you Fredrik Regards, darius Citera Länk till kommentar Dela på andra webbplatser More sharing options...
tiagra Postad 19 Mars , 2013 Rapport Share Postad 19 Mars , 2013 Hi, I _think_ the email is wrong. Try kurt.bjorck@volvo.com instead .martin Citera Länk till kommentar Dela på andra webbplatser More sharing options...
darius_ro1 Postad 19 Mars , 2013 Rapport Share Postad 19 Mars , 2013 I tried to send an email, but the email address seems to not be valid. My email came back. Do you have some other contact data of Kurt? thank you darius Citera Länk till kommentar Dela på andra webbplatser More sharing options...
darius_ro1 Postad 19 Mars , 2013 Rapport Share Postad 19 Mars , 2013 You are right Martin, it is working now. thanks darius Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Fredrik L Postad 19 Mars , 2013 Författare Rapport Share Postad 19 Mars , 2013 My bad Citera Länk till kommentar Dela på andra webbplatser More sharing options...
darius_ro1 Postad 19 Mars , 2013 Rapport Share Postad 19 Mars , 2013 thank you anyway. I am curious to see his answer. darius Citera Länk till kommentar Dela på andra webbplatser More sharing options...
65corvette Postad 20 Mars , 2013 Rapport Share Postad 20 Mars , 2013 Hej Frederik Har du mulighed for at scanne ind det dokument og maile det til mig Bk@fynsnaturpleje.dk Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Fredrik L Postad 20 Mars , 2013 Författare Rapport Share Postad 20 Mars , 2013 Hej Frederik Har du mulighed for at scanne ind det dokument og maile det til mig Bk@fynsnaturpleje.dk You got mail Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Fredrik L Postad 20 Mars , 2013 Författare Rapport Share Postad 20 Mars , 2013 Så här ser det ut ifall någon mer undrar. 1 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
darius_ro1 Postad 20 Mars , 2013 Rapport Share Postad 20 Mars , 2013 Henrik I missed your question before. The engine was in Romania and the guy asked around 3000 euro for complete assembly (engine, gearbox, transfer box) how does that sound? I discussed with him last time around 2-3 months ago. darius Citera Länk till kommentar Dela på andra webbplatser More sharing options...
darius_ro1 Postad 20 Mars , 2013 Rapport Share Postad 20 Mars , 2013 would you please translate it Frederick? Google seems to be unable to translate it and I do not understand swedish. thanks darius Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Pvpjtgb1111 Postad 20 Mars , 2013 Rapport Share Postad 20 Mars , 2013 I gave it a shot at translating, I hope it is understandable "Hereby, we accept replacement of the engine in Volvo C036X600 ... with registration number XXX XXX to engine type Mercedes 300 Turbo Diesel. Max power: 130 kWRegarding the assembling work, we take no responsibility since this is done without our supervision.This is on the conditions that the maximum authorized axle loads are not exceeded." Citera Länk till kommentar Dela på andra webbplatser More sharing options...
kristaga Postad 20 Mars , 2013 Rapport Share Postad 20 Mars , 2013 AttestationHereby we approve the change of engine in Volvo C036X600??? with registration number ???? to engine type Mercedes 300 Turbo Diesel. Max. output 130 kW.Regarding the quality of the installation we will not take any responsibility since this has been done without our supervision.This is valid as long the maximum allowed axle load is not exceeded.Göteborg (Gothenburg) May 5th 2011.Volvo heavy trucksVehicle technicalsignatureCompany number 556013-9700 Edit: After posting the translation I saw that Pvpjtgb1111 had already translated it... Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Knudsen Postad 20 Mars , 2013 Rapport Share Postad 20 Mars , 2013 Hi darius Thanks Ok the engines are in demand. But not something I would bet on. The price is not really out of place. But it is easier to buy a whole car and drive home. When you have taken what you need, you can sell the rest. Often the pieces for parts is moor expensive than the car itself. If you still think in Toyota engine, I would recommend the 4 cylinder D4D. They run well and use SUBSTANTIAL less fuel than the 6 cylendrede. Do you want to look for a whole Toyota try to look in England. Sweden where I live is not a good place to buy Toyota. I might be able to find a 1HD FT with gearboxes for approximately 20,000 DKK in Denmark. Engine is a matter of taste and what you want. ``Want´´ include all aspects of the choice. Legislation, sound, consumption, how much does it fill, RPM, etc etc etc - Citera Länk till kommentar Dela på andra webbplatser More sharing options...
tiagra Postad 21 Mars , 2013 Rapport Share Postad 21 Mars , 2013 News from Kurt of Volvo Sweden: "... sorry I can´t get you any document regarding homologation. All I do for the Swedish market is that we write that we accept change of the engine as long as the front axel load is not overload.. " Ok? .martin Citera Länk till kommentar Dela på andra webbplatser More sharing options...
darius_ro1 Postad 21 Mars , 2013 Rapport Share Postad 21 Mars , 2013 Hi, thank you for helping with the translation to english. My Swedish knowlegde is almost null. I got today a reply from Kurt who said something similar with what Martin quoted. Here Toyota engines are quite pricy. I was looking for some Toyota 4 runner/hilux surf comeming from England and unregistered, but now seems to be bad moment to find a good one with 3 liter engine. I wait for another meeting wit some guy from the department of motor vehicle and depending on what he says regarding the registration of the modifiications, I will decide on the engine. D4D looks nice , but comes with electronics and cannot use the entire driveline as it is because the front axle driveshaft exit is on the left side. darius Citera Länk till kommentar Dela på andra webbplatser More sharing options...
tiagra Postad 22 Mars , 2013 Rapport Share Postad 22 Mars , 2013 3 sets of 11/32 ring/pinion arrived today from Jez of flyingspanners.co.uk - let the Diesel roll!!! Tnx, Jez .martin 2 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
tiagra Postad 28 Mars , 2013 Rapport Share Postad 28 Mars , 2013 May I share my happiness with you? ) .martin 2 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Fredrik L Postad 28 Mars , 2013 Författare Rapport Share Postad 28 Mars , 2013 Yeah Citera Länk till kommentar Dela på andra webbplatser More sharing options...
65corvette Postad 29 Mars , 2013 Rapport Share Postad 29 Mars , 2013 Hej Jeg tror nu ikke det er så smart at forfalske dokumenter fra Volvo . Her i Danmark er det dirket i fængsel .hvis de tyskere ikke forstår svensk må de jo få det oversat og ikke forfalske det. Er faktisk ret rystet over det. Når Volvo finder ud af det her er det fuldstændigt slut med at få noget fra dem og det gælder ikke kun her men resten af veteranbil verdenen . Man skulle hellere arbejde på et godt samarbejde med Volvo istedet for at ødelægge det 1 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Fredrik L Postad 29 Mars , 2013 Författare Rapport Share Postad 29 Mars , 2013 Why do you think its a fake? 1 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
