Just a follow up, I have the rear shocks installed and they do not require any modifications like the front.  The shock can be installed with the full shroud.  Because my truck is not loaded in the back I went with the softest setting.  This gives me a very balanced feel so far.  I might consider dropping the fronts to the mid range instead of the highest setting.
These are without a doubt one of the cheaper options available and the larger body most certainly helps for harsher trails.   Though a fancy high dollar set of Fox or King would be fun, these Gabriel GasSLX are more than any C303 will ever need.
  • 5 weeks later...
Final follow up, I took the Volvo out to Moab all last week with the new Gabriel’s. Final conclusion is they worked exceptionally well. I think the length could be a bit longer for what I was doing, but in all reality they were perfect. I did everything from high speed dirt roads to reasonably hard Rock Crawling. I don’t plan on changing a thing about my shocks.
Bonus pic below.
  • Like 9
