Just a follow up, I have the rear shocks installed and they do not require any modifications like the front.  The shock can be installed with the full shroud.  Because my truck is not loaded in the back I went with the softest setting.  This gives me a very balanced feel so far.  I might consider dropping the fronts to the mid range instead of the highest setting.
These are without a doubt one of the cheaper options available and the larger body most certainly helps for harsher trails.   Though a fancy high dollar set of Fox or King would be fun, these Gabriel GasSLX are more than any C303 will ever need.
  • 5 weeks later...
  • Replies 128
  • Created
  • Last Reply
Top Posters In This Topic
Popular Posts
Final follow up, I took the Volvo out to Moab all last week with the new Gabriel’s. Final conclusion is they worked exceptionally well. I think the length could be a bit longer for what I was doing, b
Amazon och dhl var snabba, tog inte tre veckor utan tre dagar från USA till Gbg. Har fått två av fyra och de skall på framaxeln idag.
Monroe har små hylsor, går inte att borra upp.   Har kört ut till skogen med familjen idag och är mycket nöjd med fjädringsegenskaperna, har bara bytt på framaxeln men bilen är mycket bättre att kör
Posted Images
Final follow up, I took the Volvo out to Moab all last week with the new Gabriel’s. Final conclusion is they worked exceptionally well. I think the length could be a bit longer for what I was doing, but in all reality they were perfect. I did everything from high speed dirt roads to reasonably hard Rock Crawling. I don’t plan on changing a thing about my shocks.
Bonus pic below.
  • Like 7
