Electronic ignition
i have fitted electronic ignition in mine. I fittet in a electronic ignition from an older bmw 6 cylinder bosch distributor. Not direct bolt on, but not to mutch work to make it fit. Works great, better performance and more smoother idle. If i dont remember wrong it was a bmw 5 series car from middle of 80`s the distributor come from. I can check if you want.
http://hot-spark.eu/webshop/index.php?page=details&prod=56&cat=2&group=7
I've found the invoice - took me some time, but hey!, there you go.
I recon this model is designed for vacuum distributors, but I remember have contacted them prior purchase and send them the distributor code and this was what was sent to me...
Anyway, it works.
