Micky R Postad 13 Juli , 2016 Rapport Share Postad 13 Juli , 2016 Hi any one know of an alternative carburettor for the sugga mine runs fine for a while then will not pull but will idle quite happily Citera Länk till kommentar Dela på andra webbplatser More sharing options...
54ekstrom Postad 13 Juli , 2016 Rapport Share Postad 13 Juli , 2016 Sorry if I ask a dumb question, but have you checked the carb? If I remember it is a fairly straightforward downdraught thing, Rochester or similar. The symptoms suggest a fuel delivery problem, which could be a clogged fuel filter, a troublesome fuel pump or silt/particles inside the carburettor float bowl that clogs the jet(s). All things that could be fairly easily corrected without the need to get a new carb. Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Micky R Postad 14 Juli , 2016 Författare Rapport Share Postad 14 Juli , 2016 I have an electric pump fitted and have cleaned the carb several times, it will drive for several miles then starts to slow down and then it will idle but when you try to pull away it lacks any power . I have washed the fuel tank out and fitted a filter after the pump it would be nice to keep the original Rochester carb Citera Länk till kommentar Dela på andra webbplatser More sharing options...
54ekstrom Postad 14 Juli , 2016 Rapport Share Postad 14 Juli , 2016 Odd... When the car loses power, what do you need to do to "restore" normal operation? Is it enough to restart, or does it have to sit for a while? What happens when you press the accelerator, does it just not respond or does it die? Any difference if you pump the pedal? The A6 engine (in 912 etc) has a similar carb, but it has a rev limiter fitted between carb and intake manifold; does the Sugga (ED engine) have that thingy too? Is it OK? You could disconnect the fuel line from the carb, run the electric pump for some time and let the fuel run into a container and verify that the pump can uphold a decent flow. If there is any problem with the flow, two things might need checking: 1. A6 engines also have a pre-pump filter, if the Sugga has such a filter it may want cleaning. 2. There is usually a main/reserve tank switching valve in the line from the tank. If the valve or its gasket is damaged, flow may be affected. Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Glynn Postad 16 Juli , 2016 Rapport Share Postad 16 Juli , 2016 They have an accelerator pump which can leak and also a small brass plunger which sticks. Repair kits are available in the USA. Is the problem when accelerating only? Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Costin Moga Postad 17 Juli , 2016 Rapport Share Postad 17 Juli , 2016 Rebuild carbs (Rochester) can be found on ebay.com (US). Not cheap, though. Put the carb code and Rochester in the search line. Be aware there are different models, but the exact part can be found. On the other hand, I think the problem on yours can be the floater rubbing on the carb walls. Open it and check for marks, then adjust the floater (by gentle bend of the arms) to work properly. Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Micky R Postad 18 Juli , 2016 Författare Rapport Share Postad 18 Juli , 2016 Hi thanks will have a look tonight inside the carb Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Micky R Postad 22 September , 2016 Författare Rapport Share Postad 22 September , 2016 Hi I have replaced the rotor arm now which was shorting out. The sugga has been out a few times now and seems ok so I think the rotor arm must have been breaking down fingers crossed this has fixed it . I used a megger tester to check through the ignition system 1 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
