Mecedes OM606 into TGB1314
Nick S
Hello from Australia
There are a few of us down here with Volvos
I'm putting an OM606 into a TGB1314 and was struggling with the best way of adapting the Mercedes 722.6 automatic to the Volvo transfercase.  I have decided to use a Land Rover LT230 transfer case instead and a Rakeway adaptor to join the ML722.6 box to the LT230 transfer case.  I thought someone may be interested if they are doing the same.  Attached are pics of the back of the ML722.6 box and the adaptor
Cheers
Nick
  • Like 15
Spot on Nick!
Great work with the adapter! Are the adapter pieces commercially available? I have exactly the same ideas as you for my future engine swap in one of my 6x6 rigs. I have already a LT230 on my shop floor... it has lower gearing than Volvo FD51 which is good for my big tire ideas, 44"...
Rock on!
// Klas
Hi Klas
The adaptor and shafts are available from Rakeway in the UK, you need to give Niel a call as they are not on their website yet. You can choose the high range gearing on the LT230 from 1:1, 1.2:1 or 1.4:1 low range are all the same but lower than the Volvo. Rakeway also make a short output housing for the LT230 that saves about 70mm in total length
Cheers
Nick
  • 2 years later...
  • 2 years later...
  • 4 months later...
