wagonwx Postad 20 Oktober , 2022 Rapport Share Postad 20 Oktober , 2022 I’m having some plans to replace my current 120bhp B30a engine with the 170bhp Penta AQ170 engine. I would therefore like to hear if others have made the same engine change or if people have something that says it is a bad idea. No, I don't want to get a diesel engine. Please come with your thoughts and ideas. Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Volvo Laplander Camper Postad 20 Oktober , 2022 Rapport Share Postad 20 Oktober , 2022 You planing to change the block also? If it use in with seawatercooling beware for rust. Citera Länk till kommentar Dela på andra webbplatser More sharing options...
kristaga Postad 20 Oktober , 2022 Rapport Share Postad 20 Oktober , 2022 The P camshaft on the AQ engines isn't really ideal for road use. Also, the three carburettor setup will use a lot of fuel. I would rather change the A camshaft to a K camshaft on your original engine. 10 timmar sedan, wagonwx säger: I’m having some plans to replace my current 120bhp B30a engine with the 170bhp Penta AQ170 engine. I would therefore like to hear if others have made the same engine change or if people have something that says it is a bad idea. No, I don't want to get a diesel engine. Please come with your thoughts and ideas. 2 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
