Mark_Ellis Postad 15 Mars , 2023 Rapport Share Postad 15 Mars , 2023 I'm translating the Volvo book 'Bandvagn 202 ett nydanande fordon'. I'm stuck on the word "vanenbegjutning", which is translating as water casting. The line is För slitageprovningen användes en rigg som medgav sand- och vanenbegjutning av styrtungorna. Thanks in advance. 1 1 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Vinkon Postad 15 Mars , 2023 Rapport Share Postad 15 Mars , 2023 It means that the track guides in the wear and tear-rig(/simulator) were washed over with water, just as for the sand in order to see the wear-performance for the track guides. 2 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Mark_Ellis Postad 16 Mars , 2023 Författare Rapport Share Postad 16 Mars , 2023 20 hours ago, Vinkon said: It means that the track guides in the wear and tear-rig(/simulator) were washed over with water, just as for the sand in order to see the wear-performance for the track guides. Many thanks Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Mark_Ellis Postad 16 Mars , 2023 Författare Rapport Share Postad 16 Mars , 2023 23 hours ago, Vinkon said: It means that the track guides in the wear and tear-rig(/simulator) were washed over with water, just as for the sand in order to see the wear-performance for the track guides. Could you help me with this one please - avbärare kraftigare avbärare for korri ktningslamporna pa framvagnen samt stronger bearers for the indecator lights on the front carriage Does avbärare mean brighter bulbs in the indicators, or bigger indicator unit? Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Vinkon Postad 16 Mars , 2023 Rapport Share Postad 16 Mars , 2023 20 minuter sedan, Mark_Ellis säger: Could you help me with this one please - avbärare kraftigare avbärare for korri ktningslamporna pa framvagnen samt stronger bearers for the indecator lights on the front carriage Does avbärare mean brighter bulbs in the indicators, or bigger indicator unit? Avbärare refers to some sort of deflector or console that protects something. If you look at the sides of Pltgb 903, Tgb 11 and Bv 202; they all have wooden strips on their sides, so called "avbärarlist", that reduces damage to the body if they come to close to trees and such. The "avbärare" in your text seem to refer to the protective frame around the front lighting installations. In what chapter/book is that text? 1 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Mark_Ellis Postad 16 Mars , 2023 Författare Rapport Share Postad 16 Mars , 2023 16 minutes ago, Vinkon said: Avbärare refers to some sort of deflector or console that protects something. If you look at the sides of Pltgb 903, Tgb 11 and Bv 202; they all have wooden strips on their sides, so called "avbärarlist", that reduces damage to the body if they come to close to trees and such. The "avbärare" in your text seem to refer to the protective frame around the front lighting installations. In what chapter/book is that text? Thanks So it means the guards around the indicators on the side of the cab Page 19 of Volvo's Bandvagn 202 ett nydanande fordon 2 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Vinkon Postad 16 Mars , 2023 Rapport Share Postad 16 Mars , 2023 38 minuter sedan, Mark_Ellis säger: Thanks So it means the guards around the indicators on the side of the cab Page 19 of Volvo's Bandvagn 202 ett nydanande fordon Correct 1 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
