Gäst striderexpedition Postad 21 September , 2009 Rapport Share Postad 21 September , 2009 Hi, We are new to the forum. Sorry this is in english and if possible could you reply in english. Thank you. We are building an expedition vehicle with 16 dog kennels for our sled dogs and a camper unit for ourselves. After researching for 8 months we have decided the volvo TGB's are best suited to our needs. we would like to know the following information from any forum members or staff. We need accurate specs on the TGB 20 and 30/40. We specifically need to know: the cab height and width, from the bed of the truck. The actual bed length and width of both the TGB 20 and the 30/40 true max payload for both the TGB 20 and the 30/40 if it is a flatbed Where can either a TGB 20 and/or TGB 30/40 be ordered or purchased. We will import to Canada, no problem. Thanks everyone. We want to acquire the vehicle within the next two months to have the custom kennels built and mounted and the camper added. We are planning to leave for a 1 year Baja to Alaska and Cross Canada trip starting in December or January if possible. At the end we will be settling in the Yukon and preparing to race the Iditarod and Yukon Quest dog sled races with our kids (dogs). Thanks Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gäst danneape Postad 21 September , 2009 Rapport Share Postad 21 September , 2009 Wow!!! iditarod,, seen programs on tv about that race,, tough race,, Here you have the spec´s on tgb 20,, http://www.terrangbil.net/_content/_manualer/_tgb11/Instruktionsbok_TGB20.pdf In swedish,, if you want to know what it means,, just ask here, Found this on tgb30 http://www.soldf.com/ probably also in swedish,, (couldn´t get to it from work) No question is to dumb here,, just ask and we will try to help,, english is most of the times no problem, //Danne Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gäst JDW Postad 21 September , 2009 Rapport Share Postad 21 September , 2009 And where to buy, its many links on this forum but www.surplus.se www.milmac.se www.bjm.se And the swedish supermart www.blocket.se (most private sellers, the links abowe is to company's and can be a little bit easier to export from) Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gäst W-J-M Postad 21 September , 2009 Rapport Share Postad 21 September , 2009 Hi' date='We are new to the forum. Sorry this is in english and if possible could you reply in english. Thank you.We are building an expedition vehicle with 16 dog kennels for our sled dogs and a camper unit for ourselves.After researching for 8 months we have decided the volvo TGB's are best suited to our needs.we would like to know the following information from any forum members or staff.We need accurate specs on the TGB 20 and 30/40. We specifically need to know: the cab height and width, from the bed of the truck.The actual bed length and width of both the TGB 20 and the 30/40true max payload for both the TGB 20 and the 30/40 if it is a flatbedWhere can either a TGB 20 and/or TGB 30/40 be ordered or purchased. We will import to Canada, no problem.Thanks everyone.We want to acquire the vehicle within the next two months to have the custom kennels built and mounted and the camper added. We are planning to leave for a 1 year Baja to Alaska and Cross Canada trip starting in December or January if possible. At the end we will be settling in the Yukon and preparing to race the Iditarod and Yukon Quest dog sled races with our kids (dogs).Thanks[img']smileys/PDT_Armataz_02_02.gif[/img] You don't mention whether the camper has to be arctic-proof, but assuming that it must be (while neither mentioning that you will build a camper box from scratch), I don't think any single-cab model will do, which makes a TGB40 with 'crewcab' box on the pickupbed the most decent option. Total bed-length of both TGB20 and TGB40 is about 4m (minus the crew-cab box of about 150cm?), which then leaves 2.5m for cargo on the rear. For TGB11/13/20, you can find most basic data on sizes here: http://www.markerink.org/WJM/HTML/portal-compare.htm TGB40 is much more truck, with 300HP diesel, vs 125HP gasoline of the TGB20....unless you also want to be able to travel the most narrow outback roads, I would choose a TGB40....price isn't that much different either. W-J-M2009-09-21 21:10:51 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
