C202 - parts needed
Hello guys, I bought a volvo laplander/valp/c202
it came with the B20A engine and PTO.
the engine runs well.
Most parts seem to be functioning right except that i need the following:
1. carburetor for b20A,
2. air cleaner assembly also req.
3. brake hydraulic assembly.
4,5. master and slave clutch hydraulic assembly.
6. water pump assembly is required.
if anyone can help me with finding these id be very grateful.
thank you.
Hello
You cann take the slave clutch cylinder from the Volvo 940.
i think i have other parts contact me on j-and@sol.dk
Best regards
are you jeurgen peters?
oh and is it this? are you sure this is it?
http://www.cvi-automotive.se/en/articles/2.10680.47953/clutch-slave-cyl-740-87-92900s90v90-1997-7900-non-
ill email you in a bit.
thanks mandarin
  • 10 months later...
