hoss Postad 7 Oktober , 2015 Rapport Share Postad 7 Oktober , 2015 I have 2 TGB gearboxes to sell. The first is a standard 4-speed box. I do not know the exact condition or km but it is presumed to be working correctly. Looking at the records, i think this one has only travelled 18k km The second is a special conversion. It is a standard 5-speed gearbox from a 6x6, but it has had the internal gears replaced by those from an Iveco 35-8. With ratios 1st gear 6.0:1 and 2nd gear is 3.63:1 and 5th gear is 1:1. SO very good for off road crawling. I am usnure of the distance used, but it it likely to be less than 50k km since rebuild. I am not sure of the value of these, so i am open to sensible offers. Please PM 1 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
