Wingflyer Postad 24 April , 2015 Författare Rapport Share Postad 24 April , 2015 Sten, it could be that the TS LED was on in the ashtray. The TS LED was on in Sweden already when we picked up the truck on side. Then we solved the problem with a drop of oil to the "switch" behind the grill. But TS LED light was on later on the way. We did not care all the time to the LED Panel. Klaus, I just sent you a PM. Citera Länk till kommentar Dela på andra webbplatser More sharing options...
SBAT111 Postad 26 Maj , 2015 Rapport Share Postad 26 Maj , 2015 Is the matter solved? What turned out to be the cause? Citera Länk till kommentar Dela på andra webbplatser More sharing options...
