Glynn Postad 18 April , 2016 Rapport Share Postad 18 April , 2016 Hi all my engine has big problems, it stopped running on one cylinder and started smoking on overrun .i did a compression test and five very low and one zero. I had a look up the inlet tract and found the valve is cracked. So I took the head off and the bores look worn as well. So my question is . Does anyone know a source for spares Ie valves and Pistons head gasket etc. Are there any other trucks/cars with similar parts? Or does anyone have a good engine for sale? Or which other engines are an easy fit? Thanks Citera Länk till kommentar Dela på andra webbplatser More sharing options...
