Mark_Ellis Postad 9 Mars , 2023 Rapport Share Postad 9 Mars , 2023 I was quite surprised that with such a comprehensive tool and spares kit, including Tyre valve caps and Tyre valve cores, that there is nothing to inflate the tyres with ! Or is there another list ? 1 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Vinkon Postad 9 Mars , 2023 Rapport Share Postad 9 Mars , 2023 Good point. I never thought about it. Since it's not in the list you probably just shifted to a spare wheel and replaced them or filled them up at a later occasion. Since the tire is to stiff for a crew to shift the inner tube themselves there probably was mountain of wheels by the local motor pool with some poor sucker replacing inner tubes all day... Citera Länk till kommentar Dela på andra webbplatser More sharing options...
