Vehicle Blueprints and M90 Cammo
Posted
I've got a question from Milan that I hope someone can help him with:
(I didnt found anything usefull when i searched but I know it has been questions about it before)
Dear friends,
I'm very interested in Swedish Vehicle Splinter camouflage pattern.
I have plan to do some scale models as well 3d profiles and I would like to know if you have blue prints.
I was not able to find color values(RAL) for splinter either.
ANy army manual, profiles...will be helpful.
Thank you so much,
Milan
Posted
I think that splinterpattern and M90 camouflage is not the same. I think splinterpattern is like on the canvas of tgb 1111 below.
Posted
As I understand it the terms "splinter" or "splinter pattern" generally refers to a camouflage pattern with straight edges. The names origin is probably from the german splinter pattern "Heeressplittermuster 31":
The Swedish M90 pattern is often refered to as Swedish splinter pattern.
The Swedish Army term for painting things in camouflage pattern is "mönstermålning". The manual for this can be found here: http://www.soldr.se/ click on the link M90 Cammo. I also have this in pdf-format but with lower resolution, send PM if wanted.
I believe that the pattern on the canvas of the 1111 was designed by the company Barracuda (now a part of SAAB).
Kjell
Kilen2009-02-20 09:53:21
Posted
Jag har frågat om detta tidigare, är det någon som har en högupplöst kopia på "Typex.7" från Anvisningar för mönstermålning? Det verkar som att alla exemplar från nätet kommer från samma scanning. Den är omöjlig att förstora upp så att man kan måla efter den.
Kanske nån har själva skriften "Anvisningar för mönstermålning"?
Guest Protiwa
Posted
Japp, Det är jag som har gjort den ovanstående länkade PDFn. PDT_Armataz_02_03.gif
Posted
Jamenharmansett! Den var ju i hög upplösning. Jag missade det vid första kollen. Jag har sett den med döskallen i lägre upplösning tidigare?
Typex. 7 verkar ju att vara använt i praktiken också!
Daniel, om det går att få ut lite skärpa till ur originalet skulle det vara snällt om du kunde scanna Typex. 7 i ännu högre upplösning.
// Lars
Posted
Ja, tanken var att mäta på bilden för att kunna maskera något så när rätt på bilen.
Vad kan originalet tåla tro?  600 DPI?
Guest Protiwa
Posted
ok, fixar i 600DPI, vill du ha den i 100% eller ska jag förstora den. Orginalet är i A4.
Posted
Tänkte printa i A3 men jag antar att 600 DPI på A4 blir rätt bra upplösning!
Själva mätningen tänkte jag göra i ett bildprogram så A4 blir fint.
Tackar för hjälpen!
SBA1112009-02-22 22:53:19
Guest Toolman
Posted
Har någon testat att projicera mönstret på bilen med oh projektor? Det borde göra det lite enklare att göra eventuell maskering.
Posted
Jag tänkte göra så att jag kopierar på ett rutmönster på bilden (inte bilen) som har skalenligt 1 dm sida. Har provat det förut, det blir rätt OK.
Create an account
Register a new account
Sign in
Sign In Now
