Gäst Gosia Postad 28 December , 2009 Rapport Share Postad 28 December , 2009 It's nice to say hello on your forum. We found your website looking for best solutions to our car and for now it was the best source of knowledge to our questions. Until now.. We're constructing car for offroad and we have b230ft volvo engine with m46 transmission for it. We're thinking to bring it together with fd51 transfer case (like Eile forum your forum did). There's also another way.. we can buy whole set from volvo c303 - zf s4-18 transmision with fd51 transfer case. Is it possible that this set will match b230ft engine? Or we'll have to modify flange (adapter to the engine) and clutch ? And the most important case - is it a good choice that we're thinking about? What's your opinion about zf transmission and fd51 transfer case? What about weight, gear shifting and it's reliablity. What about spare parts (it's availability) Maybe there's another way to do it quicker/easier and much better...? Please help! If you find this choice a good one - where can we buy PTO for this kit? You can answer in swedish but if it's possible please answer in english Our wordlingo translator sometimes makes simple sentence completly unclear Sorry for my mistakes - my english is far from perfect... Thanks in advance. Greetings from Poland. Gosia2009-12-28 23:01:59 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gäst ErikC304 Postad 29 December , 2009 Rapport Share Postad 29 December , 2009 Hello and welcome here! Is it a Volvo car you are building or just using Volvo parts? zf s4-18 transmision with fd51 transfer case. Is it possible that this set will match b230ft engine? In other words, the clutch housing of zf s4-18 should fit both B30 and B230, do anyone know if thats so? What's your opinion about zf transmission and fd51 transfer case? The zf I believe is not the funniest to shift, but that can maybe be blamed to the lever connection design in the TGB. Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gäst Gosia Postad 6 Januari , 2010 Rapport Share Postad 6 Januari , 2010 Thank's for the answer! Best wishes in New Year! For now it's just a plan to use volvo parts (the case is, that we have volvo 945 for spare parts... ). Our car has frame and part of body from russian military car UAZ Does anyone know about these clutch housing from zf s4-18 and clutch shaft? Does it fit to B230? thanks in advance Citera Länk till kommentar Dela på andra webbplatser More sharing options...
