Gäst denis23 Postad 25 Oktober , 2010 Rapport Share Postad 25 Oktober , 2010 Hello;) Sorry for once again speaking English, and asking stupy questions. There is quite a lot of the nice Volvo TL21 around at cheap price, and it seems a good idea to use it as donor for Sugga. So, how mechanically identical is Volvo Sugga to the Volvo TL11/21/22? Best regards, Denis Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gäst klanen 1 Postad 25 Oktober , 2010 Rapport Share Postad 25 Oktober , 2010 only gearbox is the same and axel the frame is 7cm shorter Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gäst janper Postad 26 Oktober , 2010 Rapport Share Postad 26 Oktober , 2010 but the axel´s has a anouther gear ratio. mvh JP Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gäst 912.Lars Postad 26 Oktober , 2010 Rapport Share Postad 26 Oktober , 2010 Hi Denis! This subject has been brought up before and I´m sorry to say that eventough the cars look the same in the front similarities ends there, even parts as front fenders and bonnet is not the same on the two cars. The TL11/12/22 share the design and a few parts wth the Raptgb 915 (Sugga) but vital pars such as body parts, engine and axels are not the same. The manuals for both models can be found on the front page (www.terrangbil.net), they are in Swedish put you can make the comparison in measurements and name on different parts such as engine, gearbox, carb, ignition and so on to se for yourself. So to buy a "cheap" TL22 as a donor car will be expensive in the end since you will only be able to use a few parts like headlights and relay for turn signals. The best way to get parts for the sugga is to try altyco parts or terräng-axel that has some spare parts, both new and used for the sugga. The phonenumbers/adresses for these companies can probably be found on this forum. Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gäst Magnus Postad 29 Oktober , 2010 Rapport Share Postad 29 Oktober , 2010 912/6x6 - Experiences I have made myself and I'm sure of * The front has the parallell-beam in the rear of the axle. (Sugga in the front). * I'm 99% the front axle assembly will interchange. * The sugga parallell-beam can me transfered to a 6x6 axle. * The 6x6 has a different gearing, but sometimes the 6x6 came with the same gearing as sugga. * Obviously the gearings will fit, if you want to regear your sugga * The rear axles lack the provisions to bolt a leaf spring to them. * Rear axles have sh*t on them that you have to remove before you can mount an ordinary leaf spring. * The axle housing is weldable, beforementioned leaf spring mounting can be adressed. * It's the same axle shafts. I´M POSITIVE. * The frames are _completely_ different. I men they are a f**king mile apart in many ways. * The transfer case is the same, apart from maybe the handbrake drum being there or not. * It's not the same gearbox. NOT(!) * It's not the same engine! -I mean DIFFERENT. Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gäst klanen 1 Postad 1 November , 2010 Rapport Share Postad 1 November , 2010 its depends on chnr 210 or higher Citera Länk till kommentar Dela på andra webbplatser More sharing options...
