Gäst sugga915 Postad 31 Oktober , 2010 Rapport Share Postad 31 Oktober , 2010 I saw a manual / book a while ago - I think it was for the P 2104 and was in English. It had some pictures of the chassis length and angles. Does anyone know where this manual can be found online? I need a diagram of the TP21 Sugga chassis... Thanks sugga9152010-10-31 15:16:51 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gäst Beau Postad 31 Oktober , 2010 Rapport Share Postad 31 Oktober , 2010 The total production of Sugga was 720. All sold to the swedish army. I think I have all available Sugga litteratur and all is in swedish. I don´t think there is an english Sugga manual from Volvo or swedish army. Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gäst sugga915 Postad 1 November , 2010 Rapport Share Postad 1 November , 2010 Hi - thanks for the reply. There is definitely a document somewhere but I cant remember where I found it It has the picture of the P 2104 and the 915 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gäst ryden Postad 1 November , 2010 Rapport Share Postad 1 November , 2010 If you need only the chassis, maybe the grease schematic can be of help? http://user.tninet.se/~juq669m/smorj/volvo_raptgbil915_F570-4.jpg Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gäst sugga915 Postad 1 November , 2010 Rapport Share Postad 1 November , 2010 Thank you. I have this and I also found a hard copy of another schematic - I dont know what the original document is but the schematic shows the volvo p2104 dimensions including the angles from the wheels to the chassis. The document is marked "Volvo P2104" and AKTIEBOLAGET VOLVO EXPORT DEPARTMENT GOTHENBURG SWEDEN - I think I found it online once but dont know where to find it again!! Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gäst sugga915 Postad 1 November , 2010 Rapport Share Postad 1 November , 2010 It is also marked - UR 6085. 1000. 8. 56. (Engelska) Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gäst bbftx Postad 1 November , 2010 Rapport Share Postad 1 November , 2010 Here is the chassis diagram from side and top. There is indeed an English document which Volvo wrote to market and sell its vehicles overseas. bbftx2010-11-20 20:12:43 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gäst sugga915 Postad 1 November , 2010 Rapport Share Postad 1 November , 2010 Excellent! This is exactly the drawing - do you know if there is an electronic version of the full document online? Many thanks Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gäst bbftx Postad 1 November , 2010 Rapport Share Postad 1 November , 2010 Sorry, there is not a complete version online that I am aware of. Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gäst klanen 1 Postad 1 November , 2010 Rapport Share Postad 1 November , 2010 http://www.tp21.org/english.htm or http://www.tp21.org/index.htm Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gäst sugga915 Postad 1 November , 2010 Rapport Share Postad 1 November , 2010 Excellent - that is exactly the document!! Thank you! Citera Länk till kommentar Dela på andra webbplatser More sharing options...
