Gäst sugga915 Postad 1 November , 2010 Rapport Share Postad 1 November , 2010 I love my sugga but I find it impractical to drive around regularly because of the non sychro gearbox. Has anyone got any recommendations for a fairly straightforward engine and gearbox swap? Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gäst klanen 1 Postad 1 November , 2010 Rapport Share Postad 1 November , 2010 ?????? Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gäst sugga915 Postad 1 November , 2010 Rapport Share Postad 1 November , 2010 Or I need someone to teach me how to change down the gears Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gäst bbftx Postad 1 November , 2010 Rapport Share Postad 1 November , 2010 I love my sugga but I find it impractical to drive around regularly because of the non sychro gearbox. Has anyone got any recommendations for a fairly straightforward engine and gearbox swap? What country are you located in and what chassis number is your Sugga? Engine choices available to you will depend largely on where you live. Also' date=' things depend on what "straightforward" means to you. There is likely nothing you'd be interested in that is a straight drop-in replacement for part, or all, of the powertrain. An experienced restoration mechanic would be able to make lots of different options work --- there is lots of space in the engine compartment of the Sugga. But, at a minimum, there will be fabrication involved to create mounts for the new engine and transmission. And you may have to replace the entire drivetrain, including differentials, axles, wheels. BBF TX http://www.volvosugga.org bbftx2010-12-20 19:35:43 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gäst sugga915 Postad 1 November , 2010 Rapport Share Postad 1 November , 2010 I am in the UK. Chassis number is 21-320 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
