Gäst a404tg Postad 22 November , 2010 Rapport Share Postad 22 November , 2010 Hi, I have a question. I can ride this rubber tracks yet? When I broke two ribs are one-sided. Greetings Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gäst Vinkon Postad 22 November , 2010 Rapport Share Postad 22 November , 2010 Sure At least for a while. My track has cracked once and is patched, but it still holds togethter. What is the casting-number? Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gäst a404tg Postad 27 November , 2010 Rapport Share Postad 27 November , 2010 Hi, the casting-number is 798117 Tilo Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gäst petewedi Postad 28 November , 2010 Rapport Share Postad 28 November , 2010 What is casting number? Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gäst Vinkon Postad 28 November , 2010 Rapport Share Postad 28 November , 2010 Hi' date='the casting-number is 798117 Tilo[img']smileys/PDT_Armataz_02_14.gif[/img] Ok, then there it's no reason to worry. All the bv202-tracks with the two first numbers in the casting-number that starts with 79- and above has stainless wires in them. This means that your cracks is'nt that bad as it looks. The older ones rusted quickly since those cracks provided the wires with water. //Lethal Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gäst a404tg Postad 28 November , 2010 Rapport Share Postad 28 November , 2010 Hi, thanks for the good message Greeting Tilo Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gäst a404tg Postad 30 November , 2010 Rapport Share Postad 30 November , 2010 mina framsteg, some picture "BV202N in Germany" Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gäst Vinkon Postad 30 November , 2010 Rapport Share Postad 30 November , 2010 Very nice indeed! Please tell us what you have done! What's the red "thing" in the front? Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gäst ryden Postad 1 December , 2010 Rapport Share Postad 1 December , 2010 I suspect that's a poppy Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gäst Portalpalme Postad 1 December , 2010 Rapport Share Postad 1 December , 2010 nice from palme Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gäst a404tg Postad 1 December , 2010 Rapport Share Postad 1 December , 2010 Poppy = A memory of the fallen soldiers in Afghanistan Gruß Tilo Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gäst Vinkon Postad 2 December , 2010 Rapport Share Postad 2 December , 2010 Poppy = A memory of the fallen soldiers in Afghanistan Gruß Tilo Ok, nice gesture. More about the volvo, please... Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gäst JDW Postad 2 December , 2010 Rapport Share Postad 2 December , 2010 What is casting number? = gjutbatch, dvs "serienummer" fast flera band gjorda "samtidigt" har samma nummer Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gäst ryden Postad 2 December , 2010 Rapport Share Postad 2 December , 2010 Poppy = A memory of the fallen soldiers in Afghanistan [/quote'] Is it Afghanistan now? It used to be in rememberance of the trenches in Flanders, but it's quite fitting for Afghanistan. Different kind of poppy though... Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gäst a404tg Postad 2 December , 2010 Rapport Share Postad 2 December , 2010 Poppy .. purchased and donated Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gäst a404tg Postad 11 December , 2010 Rapport Share Postad 11 December , 2010 Hi, I took some pictures. Repair of my Rubber Track Greeting Tilo Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gäst Vinkon Postad 12 December , 2010 Rapport Share Postad 12 December , 2010 Ouch! Has that "rail" snapped? I hope you can fix it! Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gäst a404tg Postad 13 December , 2010 Rapport Share Postad 13 December , 2010 Question: has anyone even used two rubber tracks? Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gäst a404tg Postad 18 December , 2010 Rapport Share Postad 18 December , 2010 I have a question, how fast is with you in BV when the road goes uphill? Sorry myenglish is not so good. Greeting Tilo Citera Länk till kommentar Dela på andra webbplatser More sharing options...
