Gäst ChristianAC Postad 21 December , 2010 Rapport Share Postad 21 December , 2010 Hi Hi This nice BV202 NF1 will go to tyskland Regards Christian fra tyskland Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gäst Beau Postad 21 December , 2010 Rapport Share Postad 21 December , 2010 Very nice! Is it a norwegian BV202 with B20? Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gäst ChristianAC Postad 21 December , 2010 Rapport Share Postad 21 December , 2010 @Beau As far as I know it is one which was originally norwegian registered, but now it comes from sweden and is swedish registred. It has a B20 engine. Within all the google-search I found an article which pointed to an central-register (military??)where you just send your chassis-number and you can get the full history of that BV202. I can't find that article again. Do you know of such register ?? Regards Christian Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gäst Schäfer Postad 21 December , 2010 Rapport Share Postad 21 December , 2010 Hi. Congratulations. I don't think you'll find a BV202 in a better condition than this one. Btw, did you see the BV202 just at the railroad crossing? Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gäst ChristianAC Postad 22 December , 2010 Rapport Share Postad 22 December , 2010 @Schäfer No. It was a daytrip coming from Trondheim to have a look at this BV202 NF1 and to make the decision to buy it. We only passt 4 to 5 trucks loaded with BV206 and spent some extra money at Lundhags and Ullfrotte. So we did not recognize any other BV202 at a railroad-crossing. Regards Christian Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gäst Schäfer Postad 22 December , 2010 Rapport Share Postad 22 December , 2010 Ah. Manchmal habe ich meine BV202 neben dem Bahnübergang, ca. 200-300 Meter von dem großen, roten industrielle Haus, wo Sie sah Ihr BV202. Meine Eltern leben dort, am Bahnübergang, und sie baute auch das Haus Conny besitzt. Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gäst broten Postad 23 December , 2010 Rapport Share Postad 23 December , 2010 z Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gäst ChristianAC Postad 25 Februari , 2011 Rapport Share Postad 25 Februari , 2011 Yes.....the BV202 is in tyskland now. Regards Christian Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gäst a404tg Postad 25 Februari , 2011 Rapport Share Postad 25 Februari , 2011 Moin, Glückwunsch, tolles Fahrzeug. Wenn du auf der Höhe Lemgo sein würdest, würde ich glatt sagen...komm mal mit dem Ding vorbei. Toll, das wieder ein BV in Deutschland angekommen ist. Gruß Tilo Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gäst borre Postad 25 Februari , 2011 Rapport Share Postad 25 Februari , 2011 Das ist ein sehr schönes exemplar was sie gefunden habe. Alles beste jetzt mit dein neuen BV202. wirst viel spass damit haben Servus Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Gäst ChristianAC Postad 4 April , 2011 Rapport Share Postad 4 April , 2011 First use in tyskland...... Regards Christian Citera Länk till kommentar Dela på andra webbplatser More sharing options...
