a404tg Postad 25 September , 2012 Rapport Share Postad 25 September , 2012 Hi Friends, I must again ask you, what carburetor is better. Should I rather take the Weber 32/36 or the SU HS6. Once the WEBER strong enough. Gruss Tilo Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Vinkon Postad 25 September , 2012 Rapport Share Postad 25 September , 2012 Use the weber and you have less worries. No membrane that cracks, no bypass-air due to worn out axle-bushings and no need to synchronize it towards another carburettor. What did you mean by the last part? Once the WEBER strong enough. Citera Länk till kommentar Dela på andra webbplatser More sharing options...
a404tg Postad 26 September , 2012 Författare Rapport Share Postad 26 September , 2012 Hi and thanks for your answer. I've heard that the SU HS6 carburettors strength should be as the Weber carburetor. Can I just build the Weber carburetors to, or should I consider? Gruss Tilo Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Vinkon Postad 27 September , 2012 Rapport Share Postad 27 September , 2012 Hi I'm sorry, but I can't understand what you are asking right now... Citera Länk till kommentar Dela på andra webbplatser More sharing options...
a404tg Postad 27 September , 2012 Författare Rapport Share Postad 27 September , 2012 hi, ok ... the weber carb brings the same performance? Gruss Tilo Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Vinkon Postad 27 September , 2012 Rapport Share Postad 27 September , 2012 I believe so, I don't think there is a big difference. But perhaps someone else here can give you a better answer than that... Citera Länk till kommentar Dela på andra webbplatser More sharing options...
a404tg Postad 8 Oktober , 2012 Författare Rapport Share Postad 8 Oktober , 2012 Hi, I bought a Weber 32/36. Finally more power. Here's a little report with pictures movies on Yout ..... Greetings from Germany http://allrad-lippe-404tg.de/bv202018.html 1 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Vinkon Postad 6 November , 2012 Rapport Share Postad 6 November , 2012 Did you notice a big or a small difference? Citera Länk till kommentar Dela på andra webbplatser More sharing options...
a404tg Postad 16 December , 2012 Författare Rapport Share Postad 16 December , 2012 Did you notice a big or a small difference? Hi, I saw it only today. Yes I now have a greater difference. My BV is now driving uphill on the road and 30 Km 42 Km Gruss Tilo Citera Länk till kommentar Dela på andra webbplatser More sharing options...
