kraap Postad 30 Januari , 2017 Rapport Share Postad 30 Januari , 2017 hi, I'm Daan, I am from Netherlands and together with my girlfriend I bought this volvo 3315. My plan is to restore it and use it as a camper. In the Netherlands they are not very common. I wonder if I can ask you for counsel and advice. In the Netherlands are no available components of the Volvo. So I hope you can tell me where I can get some part from. I do not have a list of what I need, but i will make one soon. I'm now working to repair the rusty frame. to get a good basic. Hoop to hear for you soon. Daan greetings. 4 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Beau Postad 30 Januari , 2017 Rapport Share Postad 30 Januari , 2017 Welcome here Daan. You can get all the parts you need from Olav Teigen in Norway. Not cheap but he has the lot. In Sweden you can find parts at Offroad Parts at a lower price (I think). Or you can advertice here for parts new or used. Some pictures from Olav Teigens internet shop. 1 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
c202 jp Postad 4 Februari , 2017 Rapport Share Postad 4 Februari , 2017 Hello i have some parts contact me j-and@sol.dk i live in Denmark JP Citera Länk till kommentar Dela på andra webbplatser More sharing options...
kraap Postad 4 Februari , 2017 Författare Rapport Share Postad 4 Februari , 2017 Hello guys, Thanks for your comments. I will keep it in mind. In the photo you can see i don't have the original rims with tires. Does somebody have the original rims with tires for sale? Also does someone have a part-number for: shock absorber ball joint wheel bearing front and rear Thank for any tips you may have Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Puppe Postad 5 Februari , 2017 Rapport Share Postad 5 Februari , 2017 http://www.terrangbil.net/forum/index.php?/files/category/2-volvo-903valpfelt/ On the link above you find the spare part catalogue, in Swedish reservdelskatalog. The original shock absorbers are hard to find but I used these https://www.skruvat.se/Stotdampare-P53595.aspx?utm_source=tradera&utm_medium=cpc&utm_campaign=tradera-objektbeskrivning Citera Länk till kommentar Dela på andra webbplatser More sharing options...
kraap Postad 6 Februari , 2017 Författare Rapport Share Postad 6 Februari , 2017 thanks puppe for the info Are There more part that are the same with other car? Like die wheel bearings? Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Beau Postad 6 Februari , 2017 Rapport Share Postad 6 Februari , 2017 In the Volvo Valp/C202/pvpjtg9031 forum here there is a pinned thread called Reservdelslista Volvo Valp/Felt/C202. There the members of this forum has written and discussed other parts that may fit your Volvo Valp. 2 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
