rocknroll Postad 30 Januari , 2014 Rapport Share Postad 30 Januari , 2014 My Styrebox is not working so well anymore, Search to buy a Styrebox or How can repair my Styrebox? I need it fast, so how can help me Best regards Carsten Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Wingflyer Postad 30 Januari , 2014 Rapport Share Postad 30 Januari , 2014 Hi Carsten, First, to answer your PM the other day, we are still in the CAD phase. A CAD expert is helping in his spare time, object is to make the board as small as possible and also as production friendly as possible, to minimize production cost... Still a couple of weeks away, I'm afraid, untill we have circuit boards. I can probably fix your box. You can send it or bring it yourself. :-) Cost is SEK 650 per hour Labour, plus materials. Impossible to say repair cost on your box, all depends on what's wrong with it. //Sten 1 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
