Mark_Ellis Postad 4 Januari Rapport Share Postad 4 Januari Does "St Erik's Fair, Stockholm" mean anything to anybody. This is back in 1962, and I guess was either a military vehicle display for the public, or motor show of some sort? I wondered if there's any photo albums or film clips of the event at all? Many thanks Citera Länk till kommentar Dela på andra webbplatser More sharing options...
JDW Postad 11 Februari Rapport Share Postad 11 Februari S:t Eriksmässan was an ordinary fair for consumer products, nowadays called "Stockholmsmässan", i.e the fair company that ever mayor city has.' S:t Erik was a king during the 12th century, used as a trademark for Stockholm 1 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Mark_Ellis Postad 11 Februari Författare Rapport Share Postad 11 Februari 44 minutes ago, JDW said: S:t Eriksmässan was an ordinary fair for consumer products, nowadays called "Stockholmsmässan", i.e the fair company that ever mayor city has.' S:t Erik was a king during the 12th century, used as a trademark for Stockholm @JDW I was hoping to find a catalogue or article on the vehicles displayed in 1962. Would be nice to know which one it was Citera Länk till kommentar Dela på andra webbplatser More sharing options...
JDW Postad 12 Februari Rapport Share Postad 12 Februari Maybe somewhere, but as far as i can google, it was an open fair with a broad scope. Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Mark_Ellis Postad 12 Februari Författare Rapport Share Postad 12 Februari 1 hour ago, JDW said: Maybe somewhere, but as far as i can google, it was an open fair with a broad scope. I found this book a few months ago. But I can't raise a response from the seller https://www.bokborsen.se/view/Stenlund-Josef/Raketkuppen-I-Haifa/5922122 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
JDW Postad 2 Mars Rapport Share Postad 2 Mars It wasn't any problem to contact them in Swedish, and the book where available before the "timeout" of the forum. You ca try gain with the following phrase om the Ställ en fråga om artikeln: link Hej Jag är intresserad av att köpa boken, men kan ni vänligen skicka till mig i England? Vad blir i så fall fraktkostnaden Swedish Postal office offer post & package outside EU for appr 250SEK (depending on size, max 2kg). I havent tried DHL or other options. National freight cost additional 62SEK if you need help with a decoy Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Mark_Ellis Postad 2 Mars Författare Rapport Share Postad 2 Mars 3 hours ago, JDW said: It wasn't any problem to contact them in Swedish, and the book where available before the "timeout" of the forum. You ca try gain with the following phrase om the Ställ en fråga om artikeln: link Hej Jag är intresserad av att köpa boken, men kan ni vänligen skicka till mig i England? Vad blir i så fall fraktkostnaden Swedish Postal office offer post & package outside EU for appr 250SEK (depending on size, max 2kg). I havent tried DHL or other options. National freight cost additional 62SEK if you need help with a decoy JDW hi, I used that very same message box to ask my question 😉 If I bought every book that I want to check and see if it has any relevant photos inside, I would have no room in my house to sit and work on my project 🤣 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Mark_Ellis Postad 2 Mars Författare Rapport Share Postad 2 Mars 5 hours ago, JDW said: It wasn't any problem to contact them in Swedish, and the book where available before the "timeout" of the forum. You ca try gain with the following phrase om the Ställ en fråga om artikeln: link Hej Jag är intresserad av att köpa boken, men kan ni vänligen skicka till mig i England? Vad blir i så fall fraktkostnaden ... I sent a message in Swedish, and received a response 🙂 Bodafors Antikvariat has replied: 02-03-2024 10:23 Hej Mark! Tack för din förfrågan. Hela katalogen är mycket sparsamt illustrerad. Det som finns är annonser, men inte på fordon vad jag har sett vid en genombläddring. Bästa häälsningar Ted / Bodafors Antikvariat Which Google translates as Hi Mark! Thanks for your inquiry. The entire catalogue is very sparsely illustrated. What there are are ads, but not on vehicles as far as I've seen when browsing. Best wedding receptions Ted / Bodafors Antikvariat So that's a dead end Citera Länk till kommentar Dela på andra webbplatser More sharing options...
JDW Postad 2 Mars Rapport Share Postad 2 Mars OK, quite good of Google except the wedding, it shuould be translated to "best wishes" 1 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Mark_Ellis Postad 2 Mars Författare Rapport Share Postad 2 Mars Just now, JDW said: OK, quite good of Google except the wedding, it should be translated to "best wishes" It's what I thought. But Google is better than nothing Citera Länk till kommentar Dela på andra webbplatser More sharing options...
