Kommande Evenemang
Inga kommande händelser funna -
Forum Inlägg
Some 903/3314 documents can you find here:
I don't know if you're familiar with this replacement camshaft: https://shop.klracing.se/sv/artiklar/k-kamaxel-b20.html It was said to give better torque from low engine speed and still not give you a racing engine, responding well only in the higher revs. I am not familiar with Weber carb replacements. The civilian B20's normally came with a Zenit-Stromberg and some could be equipped with twin SU's, which gave a definite extra punch to the driving, but I suppose there may be physical limits in the engine compartment that could prevent the use of horizontal carbs.
Av Brandenburger1990 · Postad
All good - you are right with that! My B18 engine is fit, got electronic ignition, a modern carburetor and runs well. The plan is - a bit more torque - and why should I touch this well running B18 - so my Lappi is now on the road - parallel I want to build a bit stronger engine - and when I`m done - put it in - together with the transmission I got here already and the transfer case. So I got second full drive set - and when I now have to buy a engine to complete it - it doesnt matter if B18 or B20 - so I like to do this with a B20 - also with electronic ignition, upgrade Weber carb... - so I can swap the complete set - get the papers changed - and can put the drive set with the B18 in stock. -
Please excuse a possibly off the mark comment here. The B18 can easily be tuned beyond the normal power of the standard 3315 engine. Another carburetter configuration, a different camshaft, a properly rebuilt ignition system or any such alteration could give you power beyond a standard B20. This kind of tuning may (at least in Sweden) be performed without having to put the vehicle through a new registration inspection, and it might be a bit simpler than an engine switch. All of course depending on the original engine being in good condition.
Hi to all. Since this spring I`m the proud owner of a L3315, which feels well here next to my Amazon restoration and my 244. I hope - somebody - got documents of a late / one of the last L3315 or L3314 - with a original B20 engine.? My Valp is in good shape, I already fixed some small things, now I build in new brake lines and hoses, and some other things. Soon I like to swap the engine from B18 to B20 - not to make it a race car - I like to get a bit more torque - so I can swim easier at german traffic, and it will be easier when I pull my HMK trailer with it. I like to get the conversion registered by german authorities, because I also like to get a higher towing capacity, than I got now in my papers ( they did a fault in the past and just listed 1000Kg ) Here from this forum I already downloaded documents with 1500 Kg towing capacity - this were from a L3314. Are there owner of late L3315 or L3314 - with a original B20 engine ? Could you please send me scans of your vehicle documents? Your name, adress - this can all be covered. Neccessary is to see the hp / kw of the B20 which is higher than the B18 and the listed towing capacity. The german authorities - just want to see a proof - that a vehicle like my L3315 - could have / had at the last production years a B20 at later versions - than they register my engine upgrade. About the swap - I know that it is simple - because I got a B20 for my Amazon - and its nearly the same engine - I got already here a transmission and a transfer case - so I can prepare everything before I swap it complete. Greetings from Brandenburg - Germany to you all Robin
Medlems Statistik
Senaste Status Uppdateringar
Hej Fänrik· 0 svar
Jag har en Volvo TGB 11 där min huvudcylinder läcker. Jag ser att du bytte packningar i din huvudcylinder, bra jobbat. Kommer du ihåg var du köpte packningssatsen ifrån? Jag kan inte hitta ett repset. Kan du hjälpa mig?
Jag vet att Tatanka har det, men det är väldigt dyrt.
Med vänlig hälsning, Henrik
hello!· 0 svar
Are you still on this forum?
Maybe you can help me deal with swedish traffic office, concerning making an Ex-military Snoslunga 77 road legal. I know it's possible, saw one sold with licence plates, but don't know how to start and which papers are needed. off course not for free, i will pay for your effort and time spent if you can help me.
I just have a tgb45, bought recently a Snoslunga and want to take it to Poland. But i think that without Swedish papers it will be impossible to registrate it in Poland.
