metalblock Postad 3 Augusti , 2015 Rapport Share Postad 3 Augusti , 2015 hi im having a problem with the steeri g on 78 c202 the problem is that its very hard and it has a littel play o it i ca t park it its that hard to can any o e help Me with this please thanks all help will be helpfull Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Rookien Postad 3 Augusti , 2015 Rapport Share Postad 3 Augusti , 2015 First things first: please post questions in new topics, not in this thread. Have you downloaded the catalogue? This car doesn´t have any servo steering so it´s hard to steer, specially when parking. You can try to loosen nut 27 on page 296 in the catalogue, then turn the screw a little bit anticlockwise, then tighten the nut again. The risk with this is that the steering might become a little less accurate. Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Wingflyer Postad 3 Augusti , 2015 Rapport Share Postad 3 Augusti , 2015 New topic opened and two posts moved here... /Admin 1 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
eile Postad 3 Augusti , 2015 Rapport Share Postad 3 Augusti , 2015 If you don't have a disconect 4x4 break contact and try to park and recently push the break all fourweels will try to do move same. Citera Länk till kommentar Dela på andra webbplatser More sharing options...
