Glynn Postad 9 September , 2015 Rapport Share Postad 9 September , 2015 My sugga master cylinder is connected to the foot pedal using the upper hole in the lever is this normal? Or should I use lower hole? My brake pedal travel is long. Thanks mvh Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Micky R Postad 18 September , 2015 Rapport Share Postad 18 September , 2015 Had a look under the sugga last night and my master cylinder is connected using the upper hole ,brake pedal travel isn't to bad. Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Micky R Postad 18 September , 2015 Rapport Share Postad 18 September , 2015 Has any one fitted Toyota land cruiser wheel cylinders CS285 or CS286 to a Sugga as they look very similar Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Costin Moga Postad 18 September , 2015 Rapport Share Postad 18 September , 2015 best option is to sleeve them in stainless. trouble free. with Toyota somebody tried, but still there are modifications to do - I can't remember if he posted the end result Citera Länk till kommentar Dela på andra webbplatser More sharing options...
