Micky R Postad 22 December , 2015 Rapport Share Postad 22 December , 2015 Hi any one know what ply rating Sugga tyres should be Citera Länk till kommentar Dela på andra webbplatser More sharing options...
54ekstrom Postad 22 December , 2015 Rapport Share Postad 22 December , 2015 Are you fitting vintage tyres? If so, look for PR 8 or higher. Otherwise look at the proper grade system used today, "Load range"... The "Sugga" would need something like 2000 lbs to be on the safe side. I think... Citera Länk till kommentar Dela på andra webbplatser More sharing options...
