snetok Postad 31 Maj , 2016 Rapport Share Postad 31 Maj , 2016 with this simple device I returned springs excellent views 8 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
snetok Postad 3 Juni , 2016 Författare Rapport Share Postad 3 Juni , 2016 As a result cars rose to 4 cm at the front , 5 cm and rear. Gone clicks when the rudder in place. In addition the machine is no longer scour the road, the steering wheel has become more accurate. You should know that to put in place the springs need skill and presence of tiny hydraulic jack. Also needed will shrink tape for attaching cargo to make the axle a centering bolt spring. Watch your fingers! 3 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Beau Postad 3 Juni , 2016 Rapport Share Postad 3 Juni , 2016 It looks good but do you think your springs will keep their new shape? Another method that I have heard of but not practiced is hammer the old springs back to original shape over an anvil. Citera Länk till kommentar Dela på andra webbplatser More sharing options...
snetok Postad 4 Juni , 2016 Författare Rapport Share Postad 4 Juni , 2016 I think that the plastic deformation of the leaf springs will be more stable. Impact on the anvil deformation leads only to the upper layer hardening steel. Due to this curved sheet. Also it is impossible to tap out the sheet evenly. It is also possible the emergence of hotbeds of tension in the case of a sharp bounce hammer. And then the sheet may burst at this point. For the rest, time will tell. But I think that if the spring gives way, then a little and a very long time. 2 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
eile Postad 4 Juni , 2016 Rapport Share Postad 4 Juni , 2016 kör bladen i en ringbock, blocket bild 1 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
snetok Postad 5 Juni , 2016 Författare Rapport Share Postad 5 Juni , 2016 the same eggs, only a side view Citera Länk till kommentar Dela på andra webbplatser More sharing options...
valp-67 Postad 30 Juni , 2016 Rapport Share Postad 30 Juni , 2016 Take a small pulling spring heat it with lighter or such, gently pull it when red. Let it cool slowly. Is it The same as before? This Made me thinking some years ago.. Citera Länk till kommentar Dela på andra webbplatser More sharing options...
snetok Postad 30 Juni , 2016 Författare Rapport Share Postad 30 Juni , 2016 For bake evenly and precisely heating the entire length of the springs and also a predetermined uniform cooling skorostyu.A same tempering furnace for the same kriteriyami.I everything is superimposed on the unknown metal, the heat treatment of the unknown map 1 Citera Länk till kommentar Dela på andra webbplatser More sharing options...
