Brian Postad 17 Februari , 2019 Rapport Share Postad 17 Februari , 2019 Hi again in need of your experience,have original tank and sender ,has two contacts and an earth contact does anyone know what goes where as wires are missing? Or a diagram? Thanks for all your help. Citera Länk till kommentar Dela på andra webbplatser More sharing options...
kristaga Postad 18 Februari , 2019 Rapport Share Postad 18 Februari , 2019 You must specify what car you have. If you have the 24 Volt L3314HT, the wiring diagram is here: (number 80 is tank level giver and number 45 is the fuel indicator instrument, 41 is instrument light): Citera Länk till kommentar Dela på andra webbplatser More sharing options...
eile Postad 18 Februari , 2019 Rapport Share Postad 18 Februari , 2019 If it is a c202 and sender don't work this universal fits perfekt and work togeter with c202 meter. https://www.biltema.se/bil---mc/elsystem/matare/branslegivare-2000037781 The wiring on c202 is a bit odd too the meter. Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Brt Postad 12 Augusti , 2019 Rapport Share Postad 12 Augusti , 2019 Hi Eile, do the holes match exact? Do you think this is the same one (in Dutch)? it has a meter included but looks the same. if you google the article number you get better pictures ( a little bit better). It mentions depth of tank between 130 and 660 mm. That should be ok for a c202. Looks very similar to me link to Dutch shop: https://www.bootland.nl/diverse-aanbiedingen/brandstofmeter-inclusief-universele-tankzender.html Citera Länk till kommentar Dela på andra webbplatser More sharing options...
eile Postad 12 Augusti , 2019 Rapport Share Postad 12 Augusti , 2019 Look like the same, biltema had two models but same oder number, holes fits. I need extra long my tank is extended but the meter was easy to short down. I think mine was 10-180 omh ebay https://www.ebay.co.uk/itm/VDO-Fuel-level-sender-10-180-ohms-output-universal-6-24-inch-5-hole-mounting/113674121737?_trkparms=aid%3D1110001%26algo%3DSPLICE.SIM%26ao%3D2%26asc%3D20160323102634%26meid%3Db8d9460f07c14dfba5619d5ae3b9daeb%26pid%3D100623%26rk%3D2%26rkt%3D6%26sd%3D113674116308%26itm%3D113674121737%26pg%3D2047675&_trksid=p2047675.c100623.m-1 I think its also possible to use meter for boats: https://www.biltema.se/bat/batmotor/tankinstrument/nivagivare-2000037601 or this:TANKGIVARE VDO , VEETHREE 10-180 OHM Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Brt Postad 13 Augusti , 2019 Rapport Share Postad 13 Augusti , 2019 22 hours ago, eile said: my tank is extended Hi Eile, how did you extend the tank? Do you have pictures? i also would like a long range one or an extra one but i als have PTO and winch so the space is limited in that area. Citera Länk till kommentar Dela på andra webbplatser More sharing options...
eile Postad 13 Augusti , 2019 Rapport Share Postad 13 Augusti , 2019 Long time back my camping floor under table was extra tank total gasoline 250 liter. With diesel i dont need so much fuel so now I only use an extended original tank. Easy done cut it up on top make a box and weld. My filling hole high up on the body, for quick filling and airtight so it not lose fuel when hard driving or if car fall over side. Citera Länk till kommentar Dela på andra webbplatser More sharing options...
Brt Postad 14 Augusti , 2019 Rapport Share Postad 14 Augusti , 2019 Thanks for the pictures. Clear and good idea to use that space. I have break parts originally there (load dependent breaks) but I don’t think I will place those back and then I have the space to extend the fuel tank like you did. Thanks! Citera Länk till kommentar Dela på andra webbplatser More sharing options...
eile Postad 15 Augusti , 2019 Rapport Share Postad 15 Augusti , 2019 In my opinion, you don't need this brake thing they are more a problem on this kind of cars. But you have a extra support to tolling hook that I took away. Citera Länk till kommentar Dela på andra webbplatser More sharing options...
ExplorerII Postad 15 Augusti , 2019 Rapport Share Postad 15 Augusti , 2019 I bought one for my old 3314/903 12 volt here: https://www.okonomi-deler.no/tankmaler-4 But i dont remember wich one. They have different ohme/resistance. There is a guy in the store that drives a Norwegian L3314N, he knows. Citera Länk till kommentar Dela på andra webbplatser More sharing options...
